What did I do wrong?
Old Feb 19, 2008 | 07:41 PM
jknowles4's Avatar
Hooked up the torque converter lock up switch. Went to try it out and when I flip the switch the wait to start light comes on. I don't feel any difference in the tranny. Followed the directions on the tst website. Any help is greatly appreciated.
Old Feb 19, 2008 | 07:44 PM
BigB82789's Avatar
You probably tapped the wrong wire. There are alot of orange/black wires in there, and I think one is for the WTS light. Another thing since you have a '96 is that the early 96's need a reflash from the dealer for this to work. Just a heads up.
Old Feb 19, 2008 | 08:00 PM
jknowles4's Avatar
That's what I figured. I bet my truck is an early model also!!!
Old Feb 19, 2008 | 08:05 PM
BigB82789's Avatar
Look at the build date to see if it is. TST says 9-95 to 4-96 are affected
Old Feb 19, 2008 | 08:15 PM
B18B1LS1's Avatar
I did that too. Just tapped the wrong wire!
Old Feb 19, 2008 | 08:40 PM
jknowles4's Avatar
Yep mine is the one that needs a reflash. Build date is 9-95. That doesn't surprise me. Anyways, just went out and tapped the other wire and it seemed to work at first, then i lost first and overdrive. Hope I didn't screw anything up.
Old Feb 19, 2008 | 10:19 PM
cstroup's Avatar
I think its is number 23 in the pcm wiring harness.
Fast Eddy
Nov 11, 2005 08:11 AM
txs
Aug 17, 2005 12:21 PM
Tengu
Mar 1, 2004 11:57 PM
Paul Winey
Jan 5, 2004 06:32 PM
PistolWhipt
Mar 23, 2003 08:41 AM
