What changes torque powerband ?
I just added a #10 plate to my '97, I love the power change from stock (unbelievable
) but I have an issue with the powerband.
Truck does ok until 1700/1800rpms then kicks in very hard.
Is there any way to lower the rpm powerband ? I had a 24v and with a Van Aaken I had most of my power around 1400/1500 rpms up to 2200 then truck was flat. Since I tow quite frequently, I really like to have more torque than high rpm power.
And...yes my starwheel is full forward, # 10 plate not quite as much, I'd say 1/16" back.
) but I have an issue with the powerband.Truck does ok until 1700/1800rpms then kicks in very hard.
I have a BHAF coming next week, I had that on the 24v too, I agree it will make a difference.
I ordered it from fleetfilter.com, I didn't want to spend $ 61.00 locally, it's cheaper shipped. I will build a shield for it, it helps a lot
Ok the real thing to do here is adjust your governor arm. Yours is to low. You should have gauges. If you adjust to high your boost will go down. Adjust so you have about 34 lbs of boost. This page will help you.
http://www.cumminsdatabase.com/read.php?id=58
sallyman1
Jun 26, 2009 07:47 PM
KillerBee
Mar 26, 2007 08:06 PM
PapaSmurf
Dec 19, 2003 02:14 PM
Davidp
Feb 1, 2003 05:49 AM
