What amp fuse
Old May 14, 2003 | 04:28 AM
Drafter's Avatar
What amp fuse
I installed a VDO EGT gauge. It has power leads for both the light bulb and the gauge itself.
I looked carefully through the documentation that came with the gauge but I can't find anything about fuse sizes.
My question is "What amp fuse should I use in my painless wiring kit for the bulb power and what amp fuse for the gauge? The PWK comes with 10 amp fuses in all positions.
Thanks
Old May 14, 2003 | 06:55 AM
Stamey's Avatar
Re:What amp fuse
It depends on wire size. 16 gauge = 10 amp, 14 gauge = 15 amp, 12 gauge = 20 amp.<br><br><br>Chris
Old May 14, 2003 | 12:13 PM
TPilaske's Avatar
Re:What amp fuse
You should tap into whichever fuse controls the dimming of the panel lights on an '03. That way you can at least dim the gauge lights. The other wire should be able to be connected to any of those PWK lines. You bought the &quot;all ignition on&quot; one right?<br><br>Tony
Old May 14, 2003 | 07:07 PM
Drafter's Avatar
Re:What amp fuse
Thanks Stamey,<br><br>I will check the PWK. I believe the power wires are 16 gauge and I guess that is why it shipped with 10 amp fuses in it. I'm no electrician by any stretch of the imagination so getting some input gives me piece of mind.
Old May 14, 2003 | 07:14 PM
Drafter's Avatar
Re:What amp fuse
Tony,<br><br>Yep, your right. I bought the all ignition one. At this point I don't have power to the bulb. I'm somewhat reluctant to tap into the factory wiring. I found a post this morning that clearly identifies which wire would be correct to allow bulb control to work with the dash lighting. I was thinking I would take one of the PWK wires and put a switch on it at the base of the gauge pod so that I could control it that way. A little more hassle no doubt but it would avoid tapping the factory wire. I been down the bombing road with my last two gas powered vehicles and the warrenty issues still linger in my mind.
bigjohn92
Nov 25, 2010 01:32 PM
Stock 99 CTD
Nov 20, 2006 02:38 PM
Evildiesel
Nov 18, 2005 04:12 PM
y22man
Nov 15, 2005 05:10 PM
quantrill88
Dec 17, 2003 07:01 AM
