went from an sps62 to an HX35-12w
also went to 215 injectors from DDP4 injectors, but I've run the sps62 with stock injectors so I can make a good comparison here
wow... just wow... anyone on the fence considering one just buy one, obviously the stocker lights sooner, but really? not that much sooner!! and I don't know if anyone's ever run a drive pressure gauge w/ a stock turbo, but it's kinda spooky... I've got to play w/ the wastegate and get it dialed in, but as RPM climb, the drive pressure goes WAY up... if you've got an HX35 set at 35-36psi and you're revving to 4000rpm, I'd say you're way over 50psi driver pressure. anyhow, just couldn't believe how "laggy" the stocker really is in the grand scheme of things. |
Me either I just put a HY-9 on while my SS62 is in the shop for repair of some wheel damage and th HY spools alittle earlier but also slower...
It Sucks...wg at 23psi[duhhh] [duhhh] Jared |
