Ultimate HX35 turbo power setup ?
Looking to get max HP from my 2001.5 HO for
15 -16 second blasts on the track and still tow 8000# with stock HX35 turbo. As you can see I already have a Smarty and RV275 injectors. I want to add the Powermax3, with a water/Meth injection for short blasts. I would hookup the water injection to be activated whenever the Powermax3 was on. Would this be too much for a stock head gasket if I limit boost to 35 psi ? |
Originally Posted by Dieselcamper
(Post 1176420)
15 -16 second blasts on the track and still tow 8000# with stock HX35 turbo. As you can see I already have a Smarty and RV275 injectors. I want to add the Powermax3, with a water/Meth injection for short blasts. I would hookup the water injection to be activated whenever the Powermax3 was on. Would this be too much for a stock head gasket if I limit boost to 35 psi ? no gasket issues yet.. But anything above 35-38 psi with a stocker, you are blowing hot air. I have a 400 horse ram that probably runs about that (due to being a manual) and with a blocked wastegate i can hit over 40 psi easily, with AC on and a wastegate in place (no block in line) i hit 35 psi, and about 38 psi without the AC on. (dont have an answer for that one sorry) I still have my stock headgasket, and havent even retorqued the head yet (i know im playin with fire) but within the next few weeks a marine gasket and ARPs are gonna go in, I will admit tho, 35s are pretty quick spoolin turbos and can make for alot of fun :D Serious BOMBing has commenced with mine as of late Rick |
Why not upgrade turbo if you're worried about heat? Or atleast a 14cm gated housing. Your heat shouldn't be too bad I wouldn't think with the combo and pm3 and I wouln't worry about your HG.
I just want to see how far I can go
without changing the stock turbo[guitar] |
For future reference , when I bought this truck to
replace our tired Chevy Tahoe. I said it was going to stay STOCK[duhhh] |
(Post 1176734)
Hybrid turbo would probably help.
I'm kinda wantin to do the same thing, but no meth and maybe a Hot rod pump. Mine won't be a tow truck so that helps a little. |
would a hot cam help in all aspects of having the stock turbo? what about upgrading to twins later on, would the cam need to be changed again?
(Post 1176739)
I said it was going
Look up one of HOHN's old posts about this.
Helix 2 cam, a Megamouth DP, and some other things were on his list of thing he thought would help!! Personally, a turbo is required IMHO. Our engines don't breathe well, so we have to move it in under pressure, which takes bigger, stronger chargers!! Chris |
Just went through what your looking for, BUT I installed BD super single, with 90 stickes and comp box I can lay down 425 on the ground. I do set the comp back when towing I have a 31foot fifth it seems to pass others with no prolbem[laugh]
