Type F trans fluid ?
In my offshore boat I am running Huber 923 Borg Warner 10-18 transmissions, they demand that you run type F fluid to maintain maximum clutch holding force. I think it is because type F lacks all the friction modifieres to maintain a smoth shift, Soooo, if you have a built transmission would it be better to run Type F if you want a firm shift and and to hold up to more Tq. ?
i just changed mine and did a little research. put dextron w/ bottle of lubeguard. upon search most big name tranny builders recommend it for their trans. make sure u get all old fluid out and dont forget a filter [coffee]
No- you want to run what the manufacturer says to run- type F can create clutch chatter because it doesn't allow the plates to smoothly engage without the friction modifiers. This can be minor or major and can induce shuddering.
Originally Posted by golddusters5703
(Post 1996822)
