Dead pedal no throttle
Old 05-30-2018, 07:31 PM
ttmcb14's Avatar
Angry Dead pedal no throttle
so iv got this 2004 3500 6 speed. no throtle. just idle. ran the codes p2121 and p2127 so i replaces tps/apps witchever one you want to call it. also it is the one under the battery tray. it had a pedal for about 5 min and the dead pedal again, same codes. randomly pushing on the pedal it will work and i have throttle agian but most of the time nothing. any ideas im stuck and dont really know how to test it or where it runs befor or after
Old 06-11-2018, 04:14 PM
AlpineRAM's Avatar
If you have a spare (new-ish)battery. install it and try again.
If not, remove and insulate the big cable from the alternator and try again ( note, the truck will run on the battery, and depending on the capacity will stop working after some time)
ttmcb14
06-06-2018 10:05 AM
600 Megawatts
03-26-2008 07:09 PM
vikingsven
10-29-2006 08:28 PM
billygoat02
12-30-2005 09:19 AM
cLAYH
02-06-2004 10:59 AM
Quick Reply: Dead pedal no throttle
