TST/Smarty issue
dyno reads true MPH, our trucks ecm only reads the mph as it comes from the abs sensor...bigger tires will throw your speedo off enough that 132mph is prolly real close 117 on the speedo.
i have the complete oposite of you guys with my smarty. pulls hard through every gear till 3650 to 3700 rpms then thifts. no defueling here but then again i only have 85% throttle on any smarty levels past sw3. i thought that everyone made the highest hp on level 3 anyways?
i hate level 3 for street driving. level 9 on the street, something less when i pull or dyno. gonna try 3 next time.
the silver bullet becomes laggy when the smarty is on level 3, wouldnt be a problem when pulling or dynoing tho.
You comments got me curious and I needed to make a trip into town anyway so I played a little. In third gear (Smarty on #3, TST on #3) my CTD pulled steady to 3200 rpm???? (all I had room for)
Maybe my TST Comp is voiding the defueling? Guess I need to try it with TST off, to be sure. What level do the standard TST's defuel? Can't remember.
RJ
Mike, My understanding was that installing basic Smarty into ECM (with latest Dodge Software) eliminated defueling??
RJ
RJ
Edit: Can you still build boost at the line using #3 without torque management kicking in?
Since we're talking about RPM's and TST stuff, here's a question that has been bothering me for some time. Where does the TST box pull a measurement of the engine RPM?? It's connected to the IP with a wire tap, has a ground connection and a MAP connection. For the purpose of the anti-defuel in the TST Comp, how does the box know what RPM you're at or does it at all?? or is it just pulling the fuel signal from the wire-tap and judging by that voltage how much fuel to add??
On the subject, I have a TST Competition stacked with a Smarty and injectors and have never noticed a defuel... nor did I notice it before the TST or when I turn the TST off. I typically run with the Smarty on SW#5 with the TST either off or on 4. I can pull all the way to 3500+ with no issues...
Now with that said I am not sure that they watch it. From my testing they pretty much base everything off of boost.
Peak power is going to be made at under 3K rpms on most trucks. One of the few exceptions I've seen is Doug Smith's 832 dyno graph because power never peaked- it just kept pulling harder and harder through the rpms. You can look st his graph's on f-1's page. You'll notice that even on his truck some of the graphs show a drop off after 2700 rpms.
My point being that just because power is decreasing later in the rpms after peak power has been made doesn't necessarily mean your truck is defueling. My tst/ smarty stack will pull hard past redline, but if I'm wfo I do feel power drop off in the higher rpms.
