TST on level 9
hey i smashed my tst remote in the door a while back so im stuck with it on level 9..... got a pull this weekend is it goin to be ok to pull with it that high up last time i pulled i left it on 6..... just don't want to blow ne thing up thnx.
What do you have as far as a clutch that would be my only concern. I don't know that much about the comp box so don't quote me on this but from I have red it doesn’t adjust the timing on the 98-02 24v but it fuels really hard so I would also be worried about egt to but then again you don't know what will happen till you try you might have a great night. Also which remote do you have the you might be able to get a new one from them by then I've dealt with them and they have been nothing but good to me. hope all this helps.[coffee]
It should be ok, I never made any more power on any level above 6 on the dyno, you'll just have more smoke and heat probably.
Brett |
Without your remote your tst powermax 3 will revert to powermax 2 fueling so you're going to be just where you wanted to be for towing. Its on TST's page.
Originally Posted by Ph4tty
(Post 2161077)
i've still got the remote and it still says level 9 on it.. just the buttons to increase and decrease the power on it won't work... should i just unplugg the remote then?
Short answer, yes =)
(Post 2161077)
I thought it just stayed on the level it was last selected too by the remote..... Jim |
Just something I remember from when I was shopping for my TST. One phone call could add a level of certainty. To be fair I have not tried unplugging my remote so I could be wrong.
