-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   truck missing (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/truck-missing-34330/)
moneyman Nov 11, 2003 05:39 PM
truck missing
WHen I stomp on her and shes pulling hard it feels like shes coughing or studdering on the way up the rpm scale. I've got the hx40 ddIII's comp with wire pierced. Any suggestions?
Shovelhead Nov 11, 2003 05:42 PM
Re:truck missing
What are the gauges reading? Especially fuel Pressure.
moneyman Nov 12, 2003 09:44 AM
Re:truck missing
fuel pressure is reading 9 psi wot
Shovelhead Nov 12, 2003 10:34 AM
Re:truck missing
I'd try cleaning all the electrical connections from the "Box" to the harness/sensors as a first step.
Especially the MAP sensor near the fuel filter canister.
HOHN Nov 12, 2003 03:03 PM
Re:truck missing
Truck missing? Did you not install a lo-jack? ;D
Justin
moneyman Nov 13, 2003 10:29 AM
Re:truck missing
problem fixed. The scotch lock was a little loose on the pump wire. Crimped her down tighter and everything went away.
Thanks
Jason
Rattletrap1 Nov 13, 2003 12:49 PM
Re:truck missing
Scotch-loks are junk.
gandrews Nov 13, 2003 01:24 PM
Re:truck missing
I don't disagree.
What are better options for tapping the pump wire?
Thanks
MCummings Nov 13, 2003 04:14 PM
Re:truck missing
Blue Chip Pump Cover.
I think about $60-$70.
www.bluechipdiesel.com
Merrick
P.S. Or solder it in, but those wires are a major pain to get to.
