truck did better than I'd hoped on the dyno!
Old Feb 6, 2007 | 09:10 PM
  #31
TOMTOM's Avatar
Sweet #'s Cool video. let us know ahead of time when your dyno'in. I was in Houston sat.
Old Feb 6, 2007 | 09:37 PM
  #32
Captain's Avatar
Do you think that deeper ground 100 plate gives much more power? And cant that be achived by just moveing a regular 100 plate forword more?
Old Feb 7, 2007 | 01:12 AM
  #33
roberts11260's Avatar
Sweet Video
Old Feb 7, 2007 | 02:09 AM
  #34
12valve's Avatar
Originally Posted by Forrest Nearing
cut 3/8 off the back of the AFC foot, ground the face of the foot flat so no defuel, ditched the cupped washer on the front of the diaphragm, put the thin washer on the front and spaced it back about .080" or so, fender washer on the back. only half the nut is threaded on the shaft!
the plate is a 100 type profile, but it's ground much deeper than a regular 100 plate
ok you have modded your afc and plate just like i did.... i took a lot of pics while at it... ill try to get em up soon, if anyone wants em pm me in a few days
its funny how much more travel the afc foot needs to get fully forward, specially having the afc slightly or half way back like i want it, for low end smoke control!
Old Feb 7, 2007 | 06:36 AM
  #35
Forrest Nearing's Avatar
mine is moved all the way forward and yes, more fuel = more power
Old Feb 7, 2007 | 08:08 AM
  #36
gunracer1's Avatar
not if you put in the longer rack plug. on my 887 pump it would hurt power and smoke like no tomorrow with all the rack that a 215 pump will do. but i have found that a 215 truck with the stock front plug will support a lot of hp.
Old Feb 7, 2007 | 05:44 PM
  #37
Captain's Avatar
longer rack plug? And is there a differance between the 887 and uhh 913? I think thats the other 215 pump.
Old Feb 7, 2007 | 06:37 PM
  #38
TxDiesel007's Avatar
Perhaps they are talking about the mack plug?
Rick
Old Feb 7, 2007 | 06:58 PM
  #39
yeah, he's talking about the Mack plug... Mike, you pretty much talked me out of that... I'm sticking w/ the stock plug.
Old Feb 7, 2007 | 07:00 PM
  #40
12valve's Avatar
yep mack plug or shimmed stock plug, like on my truck... i have in cab rack travel adjustability to see how much rack travel performs bettest
Old Feb 8, 2007 | 12:20 AM
  #41
12valve's Avatar
AFC mods pics
Old Feb 8, 2007 | 10:12 AM
  #42
Captain's Avatar
great pictures. I was pretty sure I knew what you guys ment but now I know. And knowing is half the battle..
Old Feb 8, 2007 | 08:18 PM
  #43
here's the dyno chart of the runs:
Old Feb 9, 2007 | 12:50 AM
  #44
Ph4tty's Avatar
I guess run 001 is the one that slipped the clutch? I can see why with almost 1200 lbs @ around 2100! Thats a very steep torque curve on that first run too. I'm impressed. Not quite like the one below but getting close
@@ __________________
_
Now I just want to know of the SB hits any harder
Old Feb 9, 2007 | 07:59 AM
  #45
gunracer1's Avatar
i think the green was 6th gear and the other runs were 5th gear.
