truck did better than I'd hoped on the dyno!
Old Feb 5, 2007 | 07:40 PM
BigBlue's Avatar
You would have to go and brag about your numbers now wouldn't ya.
It was neat to watch the smoke roll like that. Really need to show the hippies the tree that kept getting blasted with the smoke.
Old Feb 5, 2007 | 11:49 PM
Ph4tty's Avatar
Originally Posted by Forrest Nearing
I don't think so... especially w/ some drugs It's probably close, but with some more fuel, it'll do more as-is. It'll be toasty though.
I would like to play with a silver66 and see how it does... I'd hold onto the 62 for all around cruising around, road trips to colorado, etc.
Aren't the sps series supposed to respond well to nitrous? Given any thought to making your 62 into a SB62?
Old Feb 6, 2007 | 12:05 AM
1qckdodge's Avatar
Forest, awesome numbers truck sounds reall mean, what kind of wheels are those?
Old Feb 6, 2007 | 07:33 AM
Forrest Nearing's Avatar
they are, and I have! but the cost to upgrade to a SB is pretty high because it's essentially a different turbo... different center section, different turbine housing, only thing that stays is the compressor. so I've been on the lookout for a good deal on a used one, and as luck would have it, a board member turned me on to a good deal, so I've got a SB66 on the way!
as for nitrous... I was toying with the idea, but definately need more clutch. but that shouldn't be a problem... I called Peter yesterday, and he's building me a 3800 12CB sprung dual disk
my bank account hates me
thanks man, I wish the videos picked up more of the turbine sound of the exhaust, driving around it sounds awesome! the wheels are 01-02 alloys powdercoated black.
Old Feb 6, 2007 | 07:40 AM
PourinDiesel's Avatar
Aren't all turbos?
Old Feb 6, 2007 | 08:10 AM
Originally Posted by PourinDiesel
Aren't all turbos?
not the ones that snap the shaft in half!
Old Feb 6, 2007 | 10:04 AM
RowJ's Avatar
... turbo fired up over 2000rpm and cleaned up the smoke considerably
On the street, I don't lay into it so hard at low RPM and I'll usually roll into it below 2000, so it's actually a pretty clean setup
My mistake. I was pretty far away so guess I did not hear it light off so late! Glad it drives so well!
RJ
Old Feb 6, 2007 | 10:14 AM
Olratlr's Avatar
Way to go Forest.
Old Feb 6, 2007 | 03:38 PM
blue302stang's Avatar
Good Numbers Forrest. I still need a ride in your truck.
Old Feb 6, 2007 | 04:23 PM
12valve's Avatar
stock DV's? how much rack travel?
Old Feb 6, 2007 | 05:27 PM
Captain's Avatar
wait wait go back to the clutch. He now builds 3850 12cb DD with springs? oh what the heck. I just got mine and I dont even have 5miles on it yet and theres allready a better one out!
Old Feb 6, 2007 | 06:13 PM
sorry, I may have mistyped, we decided a 3600 12cb sprung would do the trick
Old Feb 6, 2007 | 06:14 PM
stock DV's, I'm pretty sure the front plug is my rack stop at this point
Old Feb 6, 2007 | 08:08 PM
Captain's Avatar
I ment to ask you since we seem to be getting the same sort of setup going on. What rack mods did you do to your AFC housing? I'm hopeing to hit 1100pounds at the rear wheels. You said your plate is also a custom grind is it similar to any others? i think im going to end up with a 100
Old Feb 6, 2007 | 08:25 PM
cut 3/8 off the back of the AFC foot, ground the face of the foot flat so no defuel, ditched the cupped washer on the front of the diaphragm, put the thin washer on the front and spaced it back about .080" or so, fender washer on the back. only half the nut is threaded on the shaft!
the plate is a 100 type profile, but it's ground much deeper than a regular 100 plate
