TransGo Shift or Reprogramming kit?
Old Sep 3, 2008 | 05:32 AM
smokinram99's Avatar
i have searching the transgo website for a shift kit for my 99 ctd, find out a Shift kit and a Reprogramming kit for the 47RE...what's the differences?
I have shifting problem with my auto, I wanna try a shift kit and see what change.
rob
Old Sep 3, 2008 | 08:25 AM
sleepr tsi's Avatar
When I had my tranny rebuilt by a local shop, they originaly put a shift kit but ended up with a reprogramming kit. Help to keep the converter from slipping and for harder shifts.....If you have an actual tranny problem, though, neither is a good idea.
Old Sep 3, 2008 | 11:50 AM
they install both.. I don't know. the shift kit seems to cure much problem
maybe I should buy it
Old Sep 3, 2008 | 08:59 PM
sleepr tsi's Avatar
They "removed" the shift kit and put in a reprogramign kit. I don't know what you're looking to accomplish or cure, but I would say the preprogamer is the way to go.
Old Sep 3, 2008 | 09:59 PM
wcbcruzer's Avatar
I doubt the shift kit will help it. How is it shifting now? If you go with Transgo, go with the TFOD-Diesel shift kit.
Old Sep 3, 2008 | 10:00 PM
klx650a2's Avatar
My truck goes in tomorrow for the reprogramming kit. The guy @ the shop said "do not install this kit if you have ANY tranny problems, you will only cause them to get MUCH worse, very quickly".
Just my .02
Old Sep 3, 2008 | 10:11 PM
wcbcruzer's Avatar
Well, just my advice. If you're wanting a shift kit, I'd highly recommend just getting a pre-built one from one of the experienced builders (HTS, Goerend, DTT etc). There's more to it than just changing the shift points...
Old Sep 7, 2008 | 08:07 PM
luke@ddp's Avatar
Up I agree..... get an aftermarket Valve Body
Old Sep 7, 2008 | 09:52 PM
oldblues's Avatar
hi
i used the tfod-diesel kit from transgo and did it myself .
i am very satisfied with it .
Old Sep 10, 2008 | 11:29 PM
cumminsdriver635's Avatar
I liked my TFOD-Diesel Transgo kit when i had it. Worth every penny. It helped my transmission hold, and shifted better. I put it in myself also. About all of the big tranny builders start with the transgo kit, and go from there with it.
Eric
Old Sep 11, 2008 | 12:11 AM
RickCJ's Avatar
rob
MSR makes a very nice DIY shift kit. Very easy to follow directions and every part you need right done to drill bits.
http://www.smrtrans.com/
you want # SM518HD $229 I like them better than Transgo.
Old Sep 11, 2008 | 09:37 PM
The great thing with the transgo is it is only about $60. Mine shifted a little too early under wide open throttle, but I think it would have been fine if I had put the 24 valve spring in it instead of the 12 valve spring.
Eric
Old Sep 12, 2008 | 08:19 AM
RickCJ's Avatar
You get what you pay for! I've used both and the MSR kit is complete and has some differant settings. What is better shifting worth to you? $5-$20-$100-$1000?
I feel the extra $150 was well worth it.
What do you think a reprogramed valve body is?
A valve body with a shift kit.
Old Sep 12, 2008 | 11:55 AM
klx650a2's Avatar
I've had the transgo reprogramming kit in for a week and what a difference. Its amazing. Firm shifts, very quick lockup, I would not install it if you've got any sort of shifting issues as its supposed to aggravate the problem. Empty and towing, it made a huge difference. I love it!!!
Old Sep 13, 2008 | 01:16 PM
I would honestly just buy a whole valve body from a good tranny builder if i was gonna spend $220 on something just like a transgo except with a few other bells and whistles. Id still have my transgo if I hadnt of gotten a smokin deal on my valve body.
Eric
