Tranny temp or Pyro gauge
I am planning on getting either a tranny temp or a pyro gauge to go along with my boost and fp gauges.
I do alot of towing ( approx 5000lbs ) with gauge would better suit my need? |
You need a option for BOTH.
If you tow a lot your going want a tranny temp gauge. If you go ANY kind of mods you are going to want a pyro. Pyro is nice to have for cool down temps anyway. Get both. |
Another vote for both - if the truck has an automatic. If you only want 3 gauges, make it fuel pressure, trans temp, and pyrometer.
With the edge comp. and the wire tapped I'd definitly have a pyro on.
No contest......regardless of what you use your CTD for or how it is bombed, the pyro gauge is the most important gauge you will put in your truck. While a tranny temp gauge will be important for those who tow heavy (I don't count 5000 lbs as heavy), if I were to choose between the two gauges, the pyro is the obvious choice.......
You need both!
If you tow a lot your going want a tranny temp gauge. If you go ANY kind of mods you are going to want a pyro. Pyro is nice to have for cool down temps anyway. Get both. (No I didn't vote...) |
Why not get both like i did. I got the steering column mount for my tranny temp guage form Genos garage. Pyro, Boost & EGT on the window mount.
So pyro it is I guess,,,thanks for all the input
Pyro if you can only get one but both is my option....you can get the dual in one aircraft gauges from Genos....cant remember name but start with W* and great gauges.
Westach dual gauges. I have one that is pyro and boost, tranny temp in seperate ring above tunnel.
