Timing worth the Money ?
Old Aug 28, 2007 | 02:23 PM
MTNRAM's Avatar
Hi, I have a 12 Valve with a few small mods and was wondering if changing the timing is worth the money ? I was thinking about 15.5 - 16 but thats a guess. Thanks for any help or input, Ed
Old Aug 28, 2007 | 02:38 PM
dzlfarmboy's Avatar
Yeah i think you would benifit from it with milage gains and possible power bump, lower temps.
Old Aug 28, 2007 | 08:20 PM
Dhorn33's Avatar
How much does a shop charge to set the timing?
Old Aug 28, 2007 | 08:24 PM
mike_ward's Avatar
Ya, i would love to have my pump adj. also. but i dont know where to have it donr Or how much it costs.
Old Aug 28, 2007 | 08:38 PM
schaef_12's Avatar
Yes!!! Nuff said
Old Aug 28, 2007 | 11:50 PM
displacedtexan's Avatar
YES!!!
I paid $125 to have mine done.
Old Aug 29, 2007 | 12:13 AM
Muddin_dude06's Avatar
Most shops around here have quoted me $200-$220... I think the trick is how they locate TDC, from what I have been told is doing the drop valve method is the most acuarate but time consuming. Bumping the timing is deffinately worth it, my stock timing had slipped down to 8* so when I bumped to 18.5* it made it feel like going from a Ford Bronco II to a Corvette!
Old Aug 29, 2007 | 02:24 PM
Dhorn33's Avatar
What should it be at? I have a stock 97 CA emmissions truck and aside from maybe grinding my own plate it will probably stay stock for a while. What effect would timing have on fuel economy with my stock rig?
Old Aug 30, 2007 | 12:00 AM
I'd do 16.5* for economy and safety.
Old Aug 30, 2007 | 10:48 AM
Dhorn33's Avatar
I emailed a reputable shop by my house to get a price on having them do the timing on my 12v and this is the response I got:
"Injection pump is pin time to motor which was pin timed during injection pump installation. We do everything here except tires & alignments. We work on all diesels. If you have any questions please dont hesitate to call."
I am confused a little because their response leads me to believe that they won't do the timing? ***?? Did I ask the wrong question?
Old Aug 30, 2007 | 11:29 AM
dzlfarmboy's Avatar
Well if they did't understand what you meant by getting your p pump timed they probably arn't experienced with bumping timing, just R&R pumps to factory specs.
Old Aug 30, 2007 | 12:46 PM
Paul Winey's Avatar
I'm like dzlfarmboy - if they can't just say "yes we can change your timing to XX* and we do this measuring the plunger lift", then move onto to another shop. It is definitely worth going to 16.5* for fuel economy lower temps and smoother running. I'm working on going from 23 to 25 so it can be taken further but for much different reasons and with alot of other mods. .
Paul
Old Sep 7, 2007 | 01:56 AM
MTNRAM's Avatar
Sounds good, Thanks Guys . Ed
Lrdchaos
Feb 24, 2005 07:07 PM
cummins dsl
Feb 14, 2005 03:11 PM
Hoss
20
Feb 15, 2004 11:20 AM
ddestruel
Nov 11, 2003 08:46 PM
ejb
25
Aug 10, 2003 10:28 PM
