Tach?
Old Dec 18, 2002 | 03:01 PM
93w250's Avatar
Tach?
I read on the &quot;other site&quot; that a gas tach will work on my 93 if set to 4cyl. I hooked up a dwell tach to the harness under the steering column, got nothing. I also noticed the crank damper has a gap in it. I assume the pick up uses a hall effect or is their supposed to be a magnet in the gap?<br>Has anyone actually connected a gas tach to the 92/93 wiring harness successfully?<br> ???
Old Dec 18, 2002 | 08:19 PM
DJ's Avatar
DJ
Re:Tach?
Gas tach won't work. Best bet is one like isspro that will plug into the connector. An alternator tack will work but is a real pita to get hooked up unless you get one that clamps on the outside like autometer. I rember reading somewhere that you can buy an adaptor to get a gas tach to work but they were in the 80-90 dollar range. Most gas tachs also read too high too. If I get another I will get an Isspro.
danlit
Mar 20, 2003 06:29 PM
poolboy
Dec 18, 2002 08:00 AM
cuminzd
Nov 13, 2002 01:56 AM
1stGenBikeHauler
Nov 1, 2002 10:27 AM
hellotbone
Oct 11, 2002 04:04 PM
