Gage install in radio place.
Guest
Posts: n/a
Is installing gages in radio hole ( premium with CD ).
Bought a under dash mounting console, installed Sony am/FM.CD/cdrw with MP3 player.
Made a plate for radio hole, popped 3 2,1/16 holes for gages, drilled 2 9/16 holes for low fuel pressure light's ( 2 to keep it in balance ) covered it with flat black vinyl, waiting for 2 more gages to arrive, then i will connect all 3 under hood, along with low press. switch.
Dash lights is right there, mounted the one there was for pocket, where radio is now, above radio so wife can see CD slot at night, ran extension wire up to where gages are.
Hope to get 2 other in next week, have other light to put in too.
looks good ... but why didnt you just add the guages where you put the stereo ?
-and ya gatta luv that hot red velvet I swear there left over material from the 80's Dodge Valiant perimium interior
Guest
Posts: n/a
Pic from right door, note remote for radio/cd behind cup.
This setup is easy to do.
Radio/cd bracket is a universal under dash mount, got it at circuit city, so i could take it back, in case it would not work. Actually is a perfect fit.
2 angle brackets on bottom, 1 in top. Used some 3/4" wide ALU stock 1/8" thick, easy to bend and drill.
windkid4
08-31-2005 09:44 AM
NavyChief
05-23-2005 09:44 AM
