studs without o rings
how many of you here are running studs without having the head o-ringed. im right around 50psi boost and a little nervous. i need to do something. but cant afford the to do studs and have it o ringed right now.
you can put studs in right now without having the head oringed, that is what i did, that is what alot of guys do. If your headgasket does go, you wont have to buy studs again. Just make sure that you only replace one stud at a time so you dont loose the seal between the head and block
ahire
13
10-17-2008 12:50 PM
12VRoush
10-15-2007 08:00 PM
1320
03-08-2005 08:56 PM
