source for ignition power
I can't seem to locate an easy source for switched power (ignition power). I am getting ready to install my pyrometer, and all the easy obvious power sources seem to be hot all the time. As I over looking something here, or do I have to splice into a wire. If I do, which one should I look for? [duhhh]
Easiest for me was to pull the knee bolster under the column and tap into the back of the fuse panel. I think I piggy backed my stereo fuse for power to the pyro. From there you can also tap in for lights easier than pulling the wires for the switch.
I used a test light and made sure I was on the fused side that being it went dead when I pulled the fuse out. Makes for an easy clean install without all the hassle. |
I run a relay triggered by the "acc" wire in the back of the stereo.
I believe its pin 17 in the fuse box in the dash that is run-start power, which wouldn't be bad to have your gauges hooked to. Or set it to the acc-run signal, then you can watch your pyro after you shut the truck off.
just simpily place the wire in the fuse holder w/o the fuse for the ignition and place the fuse in side the fuse holder with the wire BUT your wire has to be stranded not solid.
Originally Posted by psd tuner
(Post 2119708)
| All times are GMT -5. The time now is 04:31 AM. |
