-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Smarty's Now Available in the DTR Performance Shop! (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/smartys-now-available-dtr-performance-shop-102894/)
Lary Ellis (Top) May 15, 2006 02:02 PM
Smarty's for the 98.5-2002 Cummins Powered Dodge Trucks can now be found in our store, read more Here
https://www.dieseltruckresource.com/...Smarty3422.jpg
Viperdew Jul 27, 2006 08:25 PM
Can I use the SMARTY with my Edge-EZ or will I have to remove it?
Lary Ellis (Top) Jul 27, 2006 08:34 PM
You can use them together, using one of the programs that does not advance timing would probably be the best way to go.
DIESELDENT Nov 22, 2006 01:04 PM
how about the edge comp
White Dodge Dec 11, 2006 02:17 PM
What about an edge juice with attitude??
2141pete Jan 24, 2007 08:26 PM
You can stack them but you have to run the levels on the smarty that dont add timing
Don Baggett May 17, 2007 10:08 PM
In those cases where you have to set the Smarty to not add timing, is there advantage to having the other box? Would you be just as well off to have the Smarty by itself?
NameNotInUse May 18, 2007 12:23 PM
I am in the market to buy another diesel truck and am going to buy in the 98.5-02 era and have heard a lot about the edge being the best thing for dodge, but now i am hearing quite a bit about this smarty. Anyone with opinions as to which is better? What kind of fuel mileage gains? Peak power? How much does a smarty cost?
Twogun Aug 6, 2007 09:23 PM
Smarty with stock trans.
Would not recomend the smarty with a stock auto as it adds fuel and boost early in the rpm range without bumping the auto's oil pressure. The auto and tourqe convertor are the weak link in the drivetrain and were not available with the HO motor with only 10 more horsepower. Twogun
yung cummmins Sep 23, 2007 05:50 PM
how much smoke dose the smarty make with the basic mods that i have (listed in my sig)
CumminsRedneck Nov 19, 2007 07:11 PM
1 Attachment(s)
i tried one out on my truck and it smoked more than my buddies 12v with a 100 plate, starwheel cranked all the way, fuel plate full foreward and timing advaned to 16 deg.
I was very impressed with it, does not add a ton of HP, but adds quite a bit of torque, heres a dyno sheet with my truck stock and also with smarty on SW 9
Green is stock and red is Smarty SW 9 (highest setting)
My truck is stock except for AMSOIL air filter, straight pipe, FASS fuel system, other small onn HP adding things
autocross72 Feb 18, 2008 08:43 PM
I realize this would work with my truck, but would it work with my computer running Vista?
rebel5422 Apr 8, 2008 07:33 PM
i also would like to know if this would work on my computer due to i have vista as well thanks
rebel5422 May 18, 2008 05:05 PM
my brother bought a smarty a few weeks ago used my comp to update and everything worked fine i have vista so u should be good to go
robert78.5 Nov 13, 2008 09:42 PM
I am thinking on buying something for fuel mileage and a little more power at times. Does the smarty have to plug into the obd plug under dash? And if so does it have to stay plugged in while driving?
