Smarty's Now Available in the DTR Performance Shop!
Old 05-15-2006, 02:02 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Smarty's for the 98.5-2002 Cummins Powered Dodge Trucks can now be found in our store, read more Here
Old 07-27-2006, 08:25 PM
Viperdew's Avatar
Question
Can I use the SMARTY with my Edge-EZ or will I have to remove it?
Old 07-27-2006, 08:34 PM
Admin Team Leader
You can use them together, using one of the programs that does not advance timing would probably be the best way to go.
Old 11-22-2006, 01:04 PM
DIESELDENT's Avatar
how about the edge comp
Old 12-11-2006, 02:17 PM
White Dodge's Avatar
What about an edge juice with attitude??
Old 01-24-2007, 08:26 PM
2141pete's Avatar
You can stack them but you have to run the levels on the smarty that dont add timing
Old 05-17-2007, 10:08 PM
Don Baggett's Avatar
In those cases where you have to set the Smarty to not add timing, is there advantage to having the other box? Would you be just as well off to have the Smarty by itself?
Old 05-18-2007, 12:23 PM
NameNotInUse's Avatar
I am in the market to buy another diesel truck and am going to buy in the 98.5-02 era and have heard a lot about the edge being the best thing for dodge, but now i am hearing quite a bit about this smarty. Anyone with opinions as to which is better? What kind of fuel mileage gains? Peak power? How much does a smarty cost?
Old 08-06-2007, 09:23 PM
Twogun's Avatar
Smarty with stock trans.
Would not recomend the smarty with a stock auto as it adds fuel and boost early in the rpm range without bumping the auto's oil pressure. The auto and tourqe convertor are the weak link in the drivetrain and were not available with the HO motor with only 10 more horsepower. Twogun
Old 09-23-2007, 05:50 PM
yung cummmins's Avatar
how much smoke dose the smarty make with the basic mods that i have (listed in my sig)
Old 11-19-2007, 07:11 PM
CumminsRedneck's Avatar
i tried one out on my truck and it smoked more than my buddies 12v with a 100 plate, starwheel cranked all the way, fuel plate full foreward and timing advaned to 16 deg.
I was very impressed with it, does not add a ton of HP, but adds quite a bit of torque, heres a dyno sheet with my truck stock and also with smarty on SW 9
Green is stock and red is Smarty SW 9 (highest setting)
My truck is stock except for AMSOIL air filter, straight pipe, FASS fuel system, other small onn HP adding things
Attached Thumbnails Smarty's Now Available in the DTR Performance Shop!-scanned-items.jpg
Old 02-18-2008, 08:43 PM
autocross72's Avatar
I realize this would work with my truck, but would it work with my computer running Vista?
Old 04-08-2008, 07:33 PM
rebel5422's Avatar
i also would like to know if this would work on my computer due to i have vista as well thanks
Old 05-18-2008, 05:05 PM
rebel5422's Avatar
my brother bought a smarty a few weeks ago used my comp to update and everything worked fine i have vista so u should be good to go
Old 11-13-2008, 09:42 PM
robert78.5's Avatar
I am thinking on buying something for fuel mileage and a little more power at times. Does the smarty have to plug into the obd plug under dash? And if so does it have to stay plugged in while driving?
Quick Reply: Smarty's Now Available in the DTR Performance Shop!
