smarty vs. edge juice with attitude
smarty or edge juice with attitude
im looking at getting a programer. i'm looking at the juice/attitude because i do not have any gauges. and i was wondering if i should get the smarty and buy a set of gauges instead.
to do it all over again i would go with the juice with attitude monitor,you get gauges and programable parameters for defueling and its looks nicer than a 3 pod pillar,also the juice tapped will give you way more power than a smarty,get the juice and if you need more later find a used smarty thier out there
RJ
I like the Attitude monitor ten times better then my crappy A-pillar mount. Cheaper too. Gauges, with electric fuel pressure will set you back about $500. That means the Juice is only $200.
I would love to try a Smarty, but the price is too high IMO. $650 for 70hp? Maybe if it was 170hp like the common rail version. If it wa $400, I would probably stack it with the Juice.
Very happy with my Juice. More low end and heck of a lot more top end then my VanAaken(just on Level One).
Go with the juice it is great and if you tap you will not be short of power! Just be sure if it is going on an auto to rebuild soon, that is what i did and the stick shifts can't hardly keep up.Get The Juice!
For the beginner with no guages the juice with att is a good setup , it does alot and the timer will pay for itself in time , smartys r awsome but for the guy with pretty much stock setup the juice is yr best bet , I got both and cant complain on ether
The Juice with Attitude is the way to go if you don't have gauges - certainly much better looking and more features. If you don't have the Smarty or have never run one, don't knock it. You don't know what you're missing. It's awesome - you won't believe that you're drdiving the same truck.
<On Edit> Mine would slip the stock clutch on level 3 with fuel at 3. No joke.
Yep gotta jump on the wagon with another vote for the Edge w/ TUDE!! The Smarty is cool, but doesn't have all the toys that the Edge does plus you get gauges with it!!
~Nick
P.S. I see we got another Colorado boy on here now
~Nick
gsmopar
23
Apr 27, 2007 04:39 PM
CumminsDreamin
Feb 13, 2007 08:01 PM
hotrod929
18
Feb 13, 2007 05:51 AM
bluebull
22
Feb 8, 2007 09:48 PM
