Shifting Problem
Shifting Problem
Okay so I just bought a 98 dodge ram 1500 360 5.9L V8 engine with the 46RE Automatic Transmission.. and I was driving over to a buddys it ran perfectly fine. When I went home for some odd reason it shifts gears way way to early. I noticed it when i was going down a dirt road going 80km/h and it was sitting at about 1500rpm with no power. Even when I floor it it would do nothing it wouldn't down shift to give me power or nothing. I'd slow right down give it gas and it would accelerate but when I got up to I'd say 2 or 3rd gear it would just start to upshift to top gear and I'd have no power. I need some ideas to what could be the problem. The transmission was changed out with a new one 3 years ago. (Or so the guy says) even when I got home and put it into park it idled high. It would fluctuate from normal rpm (750ish) to nearly 2k it wouldnt fluctuate super bad but slowly. Any ideas? I dont need the wife to get mad that I wasted money on a broken truck.
Okay so I just bought a 98 dodge ram 1500 and I was driving over to a buddys it ran perfectly fine. When I went home for some odd reason it shifts gears way way to early. I noticed it when i was going down a dirt road going 80km/h and it was sitting at about 1500rpm with no power. Even when I floor it it would do nothing it wouldn't down shift to give me power or nothing. I'd slow right down give it gas and it would accelerate but when I got up to I'd say 2 or 3rd gear it would just start to upshift to top gear and I'd have no power. I need some ideas to what could be the problem. The transmission was changed out with a new one 3 years ago. (Or so the guy says) even when I got home and put it into park it idled high. It would fluctuate from normal rpm (750ish) to nearly 2k it wouldnt fluctuate super bad but slowly. Any ideas? I dont need the wife to get mad that I wasted money on a broken truck.
Good point, doesn't say anything about diesel. As far as giving it the gas goes, I think that does apply to mashing the go pedal, regardless of the true fuel. We shouldn't take correctness too far. I still call R-134a "freon"...Mark
Years ago, in the '90s when they banned freon, I went about telling people to stock up because of the ban. Half of them didn't believe it and the other half didn't care. I went to Autone and bought a 30 pounder for about 20 bucks. I still have it and wish that I had bought 50 of them...Mark
Well, first thing is that you check for codes, there are a lot of codes that will not trigger a check engine light.
The fluctuating and high idle sound like a idle air solenoid to me- get a can of throttle body cleaner and clean the throttle body and the idle air passages.
Do also check the throttle position sensor and the wiring. The trans shifting depends a lot on the TPS for the 3-4 and lockup control.
