rims and rim balance weights
I purchase some black steel rims and had them mounted at my local Big O. I had the stock steel rims on my 94 CTD 2500. The stock dodge rims had all the balance weights on the inside of the rims. Big O installed wieghts on the inside and out side? The outside weights did not look so great being the the stood out with them being silver against black rims. I painted the weights black so you really do not notice them. But I know in the future if the weights fall off or I need to rebalance that I will have a scratced rim from where the weights used to be!?!?!
Couldn't Big O just use the balance weights on the inside of the rim to balance?? I have 18" rims my 66 Impala and wifes car , and both have the weights on the inside. Any thoughts??????
Dave.....
Dave.....
yep, I have thoughts on this
The big O probably was simpy trying to do a better job of balancing your tires. Your tire is never out of balance on only one side (usually anyway) and the weight being distributed closer to where it is needed is usually better. Keep in mind that wieghts are NEVER exactly where they are needed, just close. Better bet is probably beads in the tire if you are worried about weights on your rims.
DuaneW
DuaneW
I would (and do) use ceramic balancing beads. No weights needed.
http://www.innovativebalancing.com/news.htm
RJ
RJ
If I wanted to use beads do I remove the weights or just leave them on and install the beads?
The charts says I need to add 4 oz of beads. What if my tire is out of balance by more than 4 oz?
4 oz is if your 285's are stock size. "Oversized Tire Chart" says 8 oz for 285's. I would call 285's on 7"(?) wheels oversized!
My 315's called for 10 oz each.
Either way.. take all lead off wheels. The beads are in the very outside of the tire, as opposed to on the rims, so it takes less weight to do the job.... due to longer "arm" (physics 101
RJ
).RJ
Originally Posted by rjohnson
4 oz is if your 285's are stock size. "Oversized Tire Chart" says 8 oz for 285's!
RJ
).RJ
Farthest point out on the TIRE....as opposed to the farthest point out on the rim! Yes, inside/center of tire.
Lead wts ride around 8" from the center of the wheel (on a 16" wheel). Beads ride about 4-5" farther away from the center. Longer arm = more force per oz of beads!
RJ
RJ
1985cucv
35
Feb 20, 2010 12:00 PM
nodakbassmaster
Feb 21, 2009 01:22 PM
ptextreme
Aug 12, 2008 10:32 AM
wreedCTD
May 9, 2007 05:29 PM
wallypedal
Jan 30, 2006 05:46 PM
