KATOOM |
12-16-2010 02:45 PM |
The return lines are low pressure so you can either cut out the damaged section and replace it with rubber hose and hose clamps or you can redo the whole thing with new hose and JIC fittings. The only problem is that the VP's overflow valve is a banjo to hard line that cant be changed and there's a T-fitting that connects the VP return with the head return which also needs to stay. So those two things will make it difficult to redo the entire return line system with anything but OEM stuff.
