rear speaker size?
Stock size is 5.25" but 6.5" will fit. If you have a quad cab you have to remove the rear door panel. There are screws in the grab handle area and one under the opening handle. The rest is x-mas tree pins and clips. You'll have to disconnect cable from handle to completely remove panel. Its pretty strait foward, but be carefull with the panel. Not sure about standard cab.
scoutman
Aug 16, 2006 09:35 PM
Patrick Campbell
Dec 16, 2004 01:53 PM
