Quick Question
Old Feb 21, 2005 | 04:22 PM
caleb c.'s Avatar
Quick Question
As I stated in a earlier post I am looking for a 24v truck.My question is,which ones are high output engines and which ones are not.Is it a year model thing?And do all 24v's have the same injector pump?
Old Feb 21, 2005 | 04:49 PM
CTD_Neil's Avatar
I believe 2000 was the first year of the HO. I read the pumps are different as well as the injectors. 2001.5 was the first year for rear disc brakes. Dont quote me on this though.
Old Feb 21, 2005 | 04:56 PM
torquefan's Avatar
I think 01 was the first year for the HO engine, and only with the 6 speed trans. 245 HP and 505 ft/lb. The injector pump looks the same, but was modified internally to provide higher pressures.
Old Feb 21, 2005 | 05:21 PM
signature600's Avatar
Yep, 2001 was the first year for the HO/6spd...the only way to tell is the VIN, Option Code's (ETH,DEE---In Glovebox, maybe?) or the easiest way is whether or not it is a 6spd (the HO's only had 6spds).
The HO's had smaller barrels and plungers running at higher injection pressures and smaller injectors than the SO pump/injectors. (This is why HO's like big injectors, and SO's respond better to boxes)
HTH,
Chris
Old Feb 21, 2005 | 06:17 PM
torquefan's Avatar
Should have mentioned, the high output is a "7" code in the VIN, the std. output is a "6".
HorseHauler
13
Mar 12, 2006 11:48 AM
WSUcougars
Dec 14, 2003 08:52 PM
hellotbone
18
Jun 25, 2003 01:16 PM
dieselcrazy
Feb 15, 2003 06:44 AM
soundbrz
Nov 19, 2002 11:36 PM
