Question about Edge EZ
I have installed an Edge EZ in my stock 1998.5 Dodge ram 2500 24 Valve.
I Did NOT Notice any "WOW" Performance increase,, I am checking fuel Mileage this week. I was just curious if you guys have noticed any Instant performance, Or Not, The edge is on the highest setting which I believe is 65 HP. I bought it used and assume it is working cause it is plugged into the truck and the truck still runs. Truck runs very good ,, BUT It always did.. Just glad I did not pay $500.00 for it. Thanks for any replies.. |
I bought a used one for 125.00. It woke my truck up modestly. Quicker reponse and pulls my TT camper much better. If you are getting the 60hp/120 tq available thru the ez, you should notice. 3rd and od on my auto is much stonger.
Originally Posted by SSweeney
(Post 1257458)
Question. Do you have a boost gauge? If so what is your boost pressure? Did you install an adjustable boost elbow or the edge boost elbow? You should be pushing 28-30 PSI.
Should make a very noticeable difference over stock. If you lug it a bit it should also make some black smoke out the exhaust when you roll back into the throttle when on the highest setting.
Boost Gauge
Originally Posted by mbfarms
(Post 1258006)
I do not have a boost gauge,(only Fuel Gauge), But DID install the restrictive Edge Elbow, I am SURE I am getting more boost,,I just have NOT Noticed any increased throttle response on low end.. It does have 4:10's and has always reved up quickly when stomping on it.. I am trying (this week) to check fuel mileage, If I can keep my foot out of it.[duhhh] Thanks |
