Quality replacement for Amsoil EaBP 100 oil filter
Does anyone know of a quality oil filter that replaces the Amsoil EaBP 100 filter? This is used with the double bypass filter system. Or do I just need to order an OEM filter and be done with it.
`Thanks in advance |
I do not believe there is a replacement filter with the same filtration specs. as the EaBP100. You would be better off ordering the Amsoil filter.
