pusher pump question
Old Dec 11, 2003 | 12:00 PM
ramcummins's Avatar
I hear you guys talking about pusher pumps. In theory the pusher pump pushes fuel to your lift pump, then on into your injection pump, right ??? So the pusher pump helps feed the lift pump, but what if the pusher pump fails? will the lift pump still be able to pull fuel past the pusher pump or will the pusher create a "dam" and not let any fuel past it. Also at what point should a guy look at getting a pusher pump ??? see sig. Thanks in advance.
Old Dec 11, 2003 | 12:08 PM
rharveysr's Avatar
Re:pusher pump question
If the push pump stops working....your lift pump WONT get fuel! The 2k 2500 that we bought for my wife had a Carter push pump on it...and it finally decided to go bad...it in effect acted like a fuel shutoff.
Running the push pump I would see 22lbs of pressure and once I removed the push pump I see 16-17lbs of pressure @ idle. With the setup on her truck right now..(DD II's and Edge EZ) on a WOT I see 11-12lbs with just the lift pump. The truck does have -6n steel braided lines which does help feed this beast.
I have looked at the new FASS system as a replacement for the lift pump in the future. This system looks like it is built to last..
Rick
Old Dec 11, 2003 | 02:33 PM
ramcummins's Avatar
Thanks rharveysr.
Old Dec 11, 2003 | 03:10 PM
barracuda's Avatar
i have a pusher pump and like it...i also have a switch so when i first start it ( for about 2-3 seconds) it's not on so the pressure to the VP isn't too high... "ZIP" is right on the initial over pressure thing
NVRENOF
Oct 24, 2007 10:08 PM
cyawallac
Feb 28, 2007 04:03 PM
Big Smoky
Mar 23, 2006 12:11 PM
wrk24wheel
May 1, 2005 07:18 PM
midwestdually
15
Dec 17, 2004 08:52 PM
