Porting 64/14 HTT & HTT Exhaust Manifold Results
Joker12Valve and I worked on a buddys truck for about 9 hours yesterday.
He has a 97 2500 Auto 12Valve with DDP Stage 3 Injectors LC Delivery Valves 64/14 Killer B2 with low bp turbine wheel. We installed a HTT Pulse Manifold which Joker12V ported (very nicely, I might add) and port matched the gaskets. He also did the same on the turbine housing on the turbo. I also did some AFC modifications to get a little more fuel to it on the top end. We also put on a set of 5" Stacks :) Buddy reports 150-200 degree drop in EGT, quicker spoolup, and a bit more power on the top end. Turbo spool is great! The truck hits 50PSI by the top of second gear, it really flys. Also, the slight surging he had upon accelleration is now gone. Overall, we're impressed by the difference everything made. We were a bit time constrained but will be porting my HTT manifold & PS 66 charger soon! (and more porting will be done on the manifold) |
yeah, I GOTTA port my ATS :(
wanted to when I was doing the head gasket, but didn't have time... 12v manifolds start out as 24v manifolds, and they barely cut into them to make the rectangle port. there's a lot of room for improvement in the first inch of each port! |
I noticed a difference in quicker spoolup and low end torque when I ported and gasket matched my exhaust manifold. Free mod too. Every little bit helps.
To bad we diden't take pic's. next time i guess, mabye with a little more time to work on the porting. It didn't take 9 hours to port, thought that is about how long it took for the feeling in my hands to come back. now i just need a head to play with..........anytakers. (to port and polish that is)
I thought there was a issue port matching the exhaust on a turbo charged engine? Do you not want to always have the manifold a little larger than the head?
on any engine, you want the inlet side to be larger than the outlet that's meeting it... manifold slightly larger than head, turbo slightly larger than manifold... if you have locating dowels, you can go exact, but there are theories that larger also prevents reversion
Originally Posted by Forrest Nearing
(Post 1200489)
(Post 1200489)
