Performance Valve Spring
Old Feb 19, 2006 | 09:36 PM
cwert87's Avatar
Could anybody tell me if I need to pull off the head inorder to get to take the valve springs off? Then could anybody tell me where I could find good performance valve springs?
Old Feb 19, 2006 | 09:46 PM
ratsun's Avatar
Try any of the reputable speed shops they will be able to set you up.
Why do you want to change them anyway?
Old Feb 19, 2006 | 09:47 PM
Willy91's Avatar
No you do not need to pull off the head in order to cahnge valve springs. Places here in Indiana where you can probably find performance springs would be Schied diesel or Haisly machine.
Old Feb 19, 2006 | 09:50 PM
cwert87's Avatar
I was told that the oem valve springs tend or sometimes cause valves to float and cause them to fall down into the piston.
Old Feb 19, 2006 | 10:02 PM
Willy91's Avatar
From what I've learned at vocational school when changing the valve springs if you bar the engine over until the piston all the way to the top the valve will rest on top of the piston but not fall all the way through.
Old Feb 20, 2006 | 07:01 AM
Jetpilot's Avatar
You can change the vale springs on the engine, Cummins makes a real nice tool for doing this. As far as valesprings go there are several different options available but not all created equal. PDW offers several options they can be seen here http://www.performancedieselwarehouse.com/850866.html
Doug
madhat
Jun 15, 2012 08:25 AM
DNRCustoms
Nov 24, 2008 09:30 PM
WhoCares79
Jun 3, 2008 11:45 AM
flynhigh205
Feb 26, 2008 10:33 AM
fishin fever
Mar 13, 2006 06:46 PM
