Performance smarty s03
I installed a smarty s03 tuner on my truck. It seems not to add any power or even smoke.
I even installed a throttle responce chip. It didn't change the throttle response.
I have been experimenting with mine for some time before I settled on a custom setting on #3. I seem to get better mileage with my setting but power drops off at the higher RPM. It's drive ability is good, too.
And smoke is the same between 3 and 5.
Are you having the upload set before unplugging. For some reason at the end of an update it flickers my fuel pressure gauge....maybe the way I have it wired.
Also, if you have an 02 make sure you have the correct version for your truck. IIRC 2000-2001.5 is a different version.
Kurt
Kurt
randallp84
Feb 10, 2010 04:47 PM
revvinkevin
Feb 1, 2008 10:45 PM
hxw5223
Dec 1, 2007 06:35 PM
smoky beast
May 30, 2006 07:25 PM
