Performance for 1995 Diesel
Old Apr 27, 2007 | 09:27 PM
Ripcoard's Avatar
I am looking for some performance ideas for my 1995 Dodge 2500 4x4 12-Valve Diesel.Already have K&N Cold Air Intake and Straight Pipe.Anything ideas will help.
Old Apr 27, 2007 | 09:49 PM
ratsun's Avatar
Boy, the list is large...what about your wallet?
You really need to be honest about what you want to do with the truck and how much power you want, the sky is the limit 1000+hp?
I say your first expense should be a good set of gauges if you don't already have them.
Old Apr 27, 2007 | 10:01 PM
quarry adams's Avatar
What kinda tranny do you have...
If you got an auto thatd be the first thing id build up
Old Apr 27, 2007 | 10:11 PM
thebestofindica's Avatar
I have a '95 as well. If you don't have gauges, I would get pyro and trans temp for sure. My first mods were killing kdp, sliding the plate full forward, adjusting timing to 16*. My next mods are #10 plate and 3k gsk, boost elbow and high flow filter. Eventually my tranny will go and I'm prepared for that. Why put in a built tranny if this one isn't shot? After tranny, I will go for new turbo such as sps62 or htb2 and then dv's and then maybe injectors. For now, I would kill kdp and slide plate full forward or grind stock plate. That should give you a little bit more juice and peace of mind in killing kdp. Let us know what you decide.
Old Apr 28, 2007 | 07:18 AM
schoust's Avatar
Hey Ripcoard our trucks our very weak to start but given time and alot of free mods you can turn it up good! I'm very pleased with what I have in my sig.
Old Apr 28, 2007 | 10:29 AM
Box5's Avatar
Grind a 100 plate, and u'll smile. But get gauges before doing that. And ur auto tranny (if thats what u have) will shutter with that plate, so it's just a matter of time before it need's to be built up alittle.
Old Apr 28, 2007 | 12:20 PM
TxDiesel007's Avatar
Well said
add a GSK to really broaden up that powerband... it will be a night and day difference over stock..... U will think that the pedal is directly linked to the rpms with how responsive it will be...
Rick
Old Apr 28, 2007 | 02:46 PM
65fury's Avatar
hey i got a 95 12v in my truck and all my mods are for my goal of 500+hp, hers what i got
-laser cut dvs
-435 injectors(not yet installed)
-#4 fuel plate
-marine head gasket
-12mm head studs
-4gsk and 60lb valve springs
-quick spool exhaust manifold
-htts 71 series 64/14 turbo
-4inch exhaust
-built tranny(auto)
hopefully with all those mods i'll be in the 500+hp range
and like everyone said, get gauges first pyro, boost, and tranny, i also got a fuel pressure gauge so i don't starve the injector pump of fuel. but it all depends on what the truck is for and the hp you want, so let us know what your plans are and we'll point you in the best direction.
jason
Don T
Aug 24, 2010 04:25 PM
mcol
19
Jan 25, 2010 08:33 PM
EverydayDiesel
19
May 22, 2007 07:20 AM
Robertschas
Aug 19, 2006 02:34 AM
