overdrive/tans temp
I just put a gorend triple disc in and now the trans temp light is on and it won't shift into overdrive.... is there a way to bypass it and just put adifferent on off switch for overdrive
there are three wires coming out of the harness on the trans that control the OD and lockup. the orange wire is the OD you can wire it to a switch that controlled by ground and run it that way.
the orange wire is for lockup i need to jump the overdrive cause it don't work with the trans temp. light on
then its the other color wire not the thick blue one in the middle. But you can just wire it to a switch that is controlled by ground.
it worked the only problem is it doesn't come out of overdrive if its still in lockup.. guess i need a valvebody
Originally Posted by 12valvetom
(Post 2577097)
jason |
| All times are GMT -5. The time now is 10:19 AM. |
