one more thing
Old May 21, 2005 | 02:40 PM
bek's Avatar
bek
one more thing
261,000 miles and never checked the waste gate, do you thinks its time? Remedies on a stocker?
Old May 21, 2005 | 03:57 PM
rockwithjason's Avatar
the best way I know to do that is to hook compressed air to the intake side of the turbo and watch the actuator for operation. The only other way to tell is to tear it down and if you are going that far you might as well rebuild. The kit is about $90 from high tech turbo. Download instructions from holeset.com
Old May 21, 2005 | 10:47 PM
kingofdodge7131's Avatar
carefull with the air comp idea, , id buy a regulator so you can control it, dunno how much it would take, , just hate to see someone decide to takke there 130 psi tank and plug her in and watch her pop haha
Old May 21, 2005 | 10:51 PM
well my experience is that the rubber coupling you use to hook up to the turbo will blow off at about 35psi so I can't see causing too much damage. hehe Use a pressure gauge like I did.
Old May 21, 2005 | 11:20 PM
Clunk's Avatar
I'm just going to bleed my airtank to around 20 psi then check, that should make something happen.
HOHN
24
Jul 20, 2009 09:34 PM
farmer0_1
Jan 16, 2008 09:20 AM
cameroneod
15
Aug 5, 2007 02:11 PM
ArcticWolf
Dec 28, 2004 10:20 AM
FiverBob
May 7, 2003 08:22 PM
