Oil Pressure Relief and Regulator specs? 24v oil pump in a 12v?
With my industrial motors (out of a bus) I'm looking to replace these two items for saftey as they are cheap. However I can find any specs on the dodge motors. The part numbers are different. The spring for the regulator and the bypass are different (part number wise)
My motor states 65psi relief. If this was the case with dodge motors then I would think, we would see less of the "my oil pressure is high" as it would start to dump to oil pan after 65psi.
Building to make 350hp. While I have the motor in the stand replacing items now. One of those are oil pump, motor runs strong and came out of a bus. While searching I came across that the updated 12v oil pump is what's on the 24 valves and it flow more oil. Didn't say how much but over all more oil.
Is this basically a "stock" high volume upgrade? In gasser world high volume can suck a oil pan dry quick (only 5-8 quarts) vs the 12 we run.
thisguy65
07-12-2017 09:39 PM
dodgediesel
11-25-2010 07:40 PM
kawi600
09-18-2008 11:26 AM
MadFrog
09-27-2006 02:04 PM
snakefarmer
01-03-2006 05:29 PM
