-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   oil pan install quick question (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/oil-pan-install-quick-question-293353/)
bill moore Aug 6, 2011 06:43 PM
screws keep pushing the gasket out at the front and back of the pan with only a little bit of screw pressure. Anyone used gasket sealer only in this situation 1104 is what i have
johnh Aug 7, 2011 06:44 PM
use contact glue
BC847 Aug 7, 2011 08:49 PM
The oil pan is internally coated with Teflon. Gasket shellac, contact-cement, etc won't stick.
Just set all the screws a couple of threads into the pan and through the gasket. Put into place and run them in.
Been there, done that. ;)
