Not sure what i have???
I bought a 2002 with a p-pump and fass 150 fuel pump. Im not really sure if that is good performance parts or if i should upgrade to something else. Also im not sure if the turbo and injectiors are stock. If the P pump and Fass are something good i should keep what should i get as far as a turbo and injectiors goes. Im looking to make a little more power. Thanks for the help
You definitely should keep the P pump and Fass.Thats the best way to go.as far as the rest,I'm not sure.
Go read in the 12v section about bumping power up and follow the recommendations. If the plate is near the rear, you can just slide it forward. If its all they way forward, you could yank it, or just put in bigger injectors. Do the free things first. Thats the point of the p-pump.
ok i will be sure to do that, thanks a lot guys.
I did also find out it also has a banks high ram intake and a sound bend clutch. |
