-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   my injector pump light is on (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/my-injector-pump-light-231380/)
CaledoniaOutlaw Jan 29, 2009 06:46 PM
My injector pump light is on in my dash , my truck is stock and doesnt appear to have lost any power. where should i start and what should i do? thanks in advance for any help. Dan
nike Jan 29, 2009 09:05 PM
you have an injector pump light? Wish mine did......................LOL
mt_rodeo Jan 29, 2009 09:12 PM
Im assuming your talking about a low fuel pressure light that alerts if the lift pump is not supplying the injection pump with enough pressure, and therefore not enough fuel.
If it is very cold, which I'm sure it is for you too with the storms in the midwest, mine will stay on constantly. Not really sure why, I just assume the cold is playing hell w/ the sending unit.
badme Jan 30, 2009 07:14 PM
Where do you find this light? Mine does not have one.
13ALPHA Jan 30, 2009 08:00 PM
Maybe a picture? I've never seen one.
nate_88 Jan 30, 2009 08:14 PM
He accidentally posted 2 of the same threads. It turned out that it was the check engine light that he was looking at and misinterpreted it as an injection pump light since it looks a little like an injection pump.
Mt_Rodeo is talking about the aftermarket light that you can buy and install. It's a simple LED light with a 5 psi sensor switch. Here's an example of one:
http://www.xtremediesel.com/bd-power...ghtkitred.aspx
Hope this clears things up
