motor home injectors?
I dont remember hearing that there is any specific "RV" injectors for the 12 valve. I have heard that anything larger than the 215's gets that engine pretty hot but then again, I'm not a 12 valve guy and my knowledge only goes so far.
Might be confused with a set of Cummins injectors for the 24 Valve known as the RV275. Don't think those were recreational vehicle specific, just for higher horsepower applications.
Those are injectors for the 24 Valve engine, not sure if there is something similar for the 12 Valve engines from Cummins.
You don't need injectors for that 230hp motor.
Been there- done that and now out $400.
If you need more power, advance the timing to 14.5 degrees and put a straight flow thru muffler on her.
Slide the plate forward .020 and put a pyrometer on her. Also put a boost controller on it and don't run that HX 35w over 32-33 psi. You don't need to change the plate either.
You don't need a 3GSK either. The pump was made for low rpm grunt. I did these mods and seldom go over 2100 rpm. That HX35 is the best for all around for that RV.
jmccart
48
07-23-2008 12:34 AM
PaulDaisy
17
11-29-2007 11:53 PM
dawghlr
06-09-2005 09:56 PM
