Most Important Guages
My Edge W/ Juice picks up all the stuff off the factory wiring/ ECM other than the trans and ETG temps.
So it won't pick up the trans temp? I thought that might be one of the signals that was picked up by the ECM for the 1996 year. I thought I read somewhere that Dodge changed that for somewhere around 2001 or so.
The trans temp requires installation of the the Edge supplied probe into the trans at a location of your choice. I believe that the Edge instructions direct you to install the probe in to the hot "out" line to the trans cooler - I could be wrong on this. I installed the probe into the available port in the BD deep pan that I have on my tranny.
Calibrating The EGT Gauge
Does anyone have a way to calibrate the EGT Gauge. I need to make sure mine is correct? I am not sure it is reading correct as the EGT seem to run real high when towing like easily reaching he 1200 Deg mark when in OD uphill or merging onto high way pulling hard
Fill out your trucks info, and this would be an easier question to answer.
If your truck is even slightly modified, getting your EGTs to 1200 is easy to do.
Since its impossible to know all the variables which can affect EGT's, start with the basics. Fill out your sig so everyone knows everything about your truck and then post was the idle EGT's are, cruising EGT's at specific speeds, and what your boost is in relation to the driving EGT's.
rip 112
05-08-2007 02:22 PM
