more psi with j-hook
My guess would be to try to build boost with the hood opened and have ureself or someone go under the hood and somehow listen for leaks. That kinda seems hard but Im not sure of any other ways to find boost leaks. I havent had to troubleshoot a boost leak before so its just my best guess. I hope this is correct and helps ya bud.
there was a thread that gave a showed how to build a fitting for the turbo that would alow you to hook a air compressor to it. i havent been able to find that thread yet. from there you add air till it starts leaking. i anyone remember what it was called and does the motor hold the pressure or do you have to close off the other end?
https://www.dieseltruckresource.com/...ght=boost+leak Is this the thread u were lookin for?? If not, maybe it'll help anyway.
ok little confused there, that guy had the same symtoms as me but he was making it to 25 psi before it droped one guy there made it seem like boost should fall off at 2500 to 2700 rpms if thats the case then it sounds like i should be looking at my vp or injectors for a fueling problem
my truck stock with a bad lift pump showed about 18 PSI then when i added the boost elbow i saw about 23 or 24. Now with my Edge COMP on EZ mode (wire not tapped) i am seeing a max of about 30. Im guessing i will see another 5-10 PSI increase when i tap my wire. Most others have told me they can get around 40 PSI on 5x5
ok trying to find boost leak but my system wont hold any pressure??? have the pump hooked up right now but nothing is happining at all, boost gage stays at 0psi, spraying everywhere not seeing any bubbles anywhere???? on the other thread one guy said to plug the intake horn, then another said not to cuz the leak might be in the intake manifold but didnt say to plug anything elce so i assumed the motor would hold the pressure?
ya did that didnt hold prussure at all thing im goint to try and get a bigger air tank and push a little bigger mass through... i hate to do it but im about ready to drop it off at a shop and tell them to give it back when its all fixed
