Max boost with Van Aaken box?
I've got a Van Aaken box on an otherwise stock '00. I was happy with the performance but decided to install a boost elbow to see if I would like the added boost even more. Well, even with the elbow adjusted to provide max boost I still can't get more than ~21psi. Is this normal for the Van Aaken box or could I have a bad box or bad connection between the MAP sensor boost fooler?
Is it a R style or v5? Some of the old R boxes didn't have boost fooling. When I had mine hooked up, I was seeing about 30psi. I also could not get over 1000* pre turbo unloaded. What are your egt's and fuel pressure?
Should be able to get about 30 psi max with the V5 and stock injectors if you really run the crap out of it. That's with the waste gate blocked off. With the 1.6's I can hit 32 psi almost immediately, that's where my elbow is set.
Bowser50
16
May 1, 2010 04:58 PM
BILL DODGE2003
Jul 18, 2004 04:28 PM
ppsi
Apr 30, 2004 10:13 AM
Battering Ram
110
Mar 25, 2004 06:14 PM
Copenhagenjunkie
May 19, 2003 08:04 AM
