MAP signal will not change
Old Nov 22, 2006 | 06:35 PM
kellio's Avatar
Question MAP signal will not change
When I installed my Commander, I noted that boost pressure was always at 0 psig even on the road. I hear turbo winding up, vanes are free to rotate and not wobbley. Waste gate rod is not stuck. No codes are generating. Voltage reading indicates a constant .5 volts +-.1 vdc. Next step is to check voltage readings from the MAP signal wire on the road to see if it is indicating a higher voltage and to check actual boost pressure at discharge of turbo. Ever hear of a MAP sensor failing at 0 psig boost signal? Any thoughts or comments?
Old Nov 23, 2006 | 11:01 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
absolutely could be a failing MAP if the diagphram ruptures that reading can result. i would try removing the commander and testing with a multi-meter or digital scope. if reading is the same then MAP is defective.
Chris
Old Nov 24, 2006 | 12:42 AM
timbeaux38's Avatar
Has the performance changed recently?
Old Nov 24, 2006 | 10:55 PM
chop342's Avatar
Performance really wont change but limp in can sometimes become and issue on a failing MAP
Old Nov 25, 2006 | 03:51 PM
kellio's Avatar
Performance has not really changed but I will take the voltage readings. I wish there was a better place to get the data than off the MAP sensor wiring. Kind of a pain to reach in and put a splice connector on the signal wire. But its doable. I'm going to also check actual boost pressure at the outlet of the turbo.
Old Nov 27, 2006 | 08:24 PM
kellio's Avatar
Success! Connected my digital voltmeter to the MAP sensor signal wire and took truck for a spin. Got .5 to 2 vdc depending on boost pressure. Hooked to the wire at the Commander card and still got the same signal with 0 psig boost indication. Quad said my MAP signal was about right so had to RA my Commander back to them. They will fix the card or get me a new one.
klx300guy8
23
Feb 20, 2008 01:53 PM
tweeder_51
Apr 23, 2007 01:38 PM
dually drooler
Nov 8, 2006 09:00 AM
Stormin_Norman
0
Jan 16, 2006 12:35 AM
CruisingRam
Sep 14, 2004 04:50 AM
