map sensor question again
Old Dec 9, 2007 | 04:32 PM
  #31
daveg's Avatar
From: Colville,in beautifull Eastern (should be a state) Washington
My Superchipped '99 lit up "check engine", I got the low voltage/low boost code which I took to mean bad MAP sensor. My boost gauge reads good, but there's a big flat spot @mid throttle, low/high rpm, starting & mpg are OK. Haven't seen the business end of the sensor, does cleaning it ever work ? It seems to be a dealer only part @ $117 + contribution to the gov. who won't send an adviser to hold my trouble light. I see someone called it a "boost sensor", is there an aftermarket replacement ? Thanks, dg.
Old Dec 9, 2007 | 04:49 PM
  #32
daveg's Avatar
Here I am, replying to myself It just occurred to me that an enterprizing individual might "hot wire" (fed.emissions law violation? wouldn't want to run afoul of the fed !) the MAP plug on a stock engine, maybe use a resistor or a potentiometer to get the desired voltage (which I think is listed in my MIA Haynes manual) Any thoughts out there ?
Thanks again, great to be back, you folks are the best ! dg.
Old Dec 9, 2007 | 10:00 PM
  #33
j.rich's Avatar
Do you need to put somthing bak in the map sensor hole like a bolt or somthing?
Old Dec 9, 2007 | 10:28 PM
  #34
timbeaux38's Avatar
You don't take the sensor out, just unplug the pigtail.
Old Mar 29, 2020 | 02:13 PM
  #35
Dent side dodge's Avatar
I did this on my 05 and all it did was put the truck in limp mode.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
