manifold and turbo gaskets
i have a twin setup that im putting on my truck. What i was wondering is when you pull the manifold and turbo flange are the gaskets reuseable or should i plan on replacing them. Also the oil drain line. If you had to replace these where did yall get all the gaskets?
Depends on mileage, but I wouldn't reuse them. You don't want to have to pull everything back off if you have a leak.
The turbo/manifold gasket is a Dodge or Cummins part. Pretty sure the block manifold gaskets are too. I have a aftermarket manifold so that's why I can't remember on that one. |
Make sure you get the new style multi layer steel for the manifold/block gaskets.
its got 120k miles. Thats pretty much what i figgured. I was wanting to find some better than stock ones and ive been looking at the MLS ones.
