LP needed to support edge juice? Delphi and Holley blue?
So I'm going to be upgrading my LP system in anticipation of installing an Edge Juice package.
Currently I have a Delphi LP in the stock location. Will adding a Holley Blue as a pusher on the frame rail with the Delphi be enough to keep up with the juice? Will I need a regulator on the Holley Blue or just run it wide open? What's a decent price for the Holley Blue?
i just installed my juice w att. I am now looking to install a holley blue on the frame rail also. I haven' t checked the price but my mechanic told me to go to O'riley's or napa that is where they are the cheapest he said he could sell me one but they would give me a better deal.
I'm not sure what psi the holley blue pump is, but most people run a add on pump that is around 7psi and mount it on the frame rail with no problems. I have to carter pumps one 18psi and one 7psi both mounted on the frame rail and it is enuff for my edge comp which is the same hp as the juice. I don't know prices on a holley pump, but my carter pumps were about $100 buck.
what is the best way to run the helper pump. cus i can watch my fuel pressure when i get on it and it drops to like 4 psi and a few times 3 so i cant get on it like i would like to.
The specs for Holley Blue are:
# Flows 110 GPH (free flow)
# Flows 88 GPH at 9 PSI
# Maximum pressure is 14 PSI
I'm guessing it will only hit the 14psi if its dead headed which shouldn't happen on a system with a return line. Whats the min psi for fuel pressure you should see at WOT?
That's exactly what I did. I have a Delphi in the stock location and added a Holly blue by the tank. I don"t have any power upgrades though. I see 26-28psi steady and pulling hard 22. I was a little concerned about this much pressure but so far no problems. I added the Holly because the Delphi would drop to 5 psi then back up, or sometimes it would stay at 5 for a while or come up when I stepped on it. No more, just steady pressure.
I've got the stocker,and a carter "pusher pump" that 9 psi thing,and I'm now needing to replace the stocker.
bought the truck with 54k changed the VP and installed a pusher-new stocker at about 130k,and at 165k another VP and at 175k now need another stock pump.
Going to try something else this time...
AlCorr
114
02-11-2009 02:32 AM
Texaschevelle
26
11-16-2007 08:08 PM
cLAYH
01-15-2007 11:06 PM
razor6
22
01-20-2006 03:43 PM
