-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Lower EGT's (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/lower-egts-51301/)
Mcmopar Sep 20, 2004 03:58 PM
Lower EGT's
I modified my Dad's 96 4X4 Dually with 4.10:1 ratioand the auto with an AFE, number 6 plate, and an AFC spring kit. While trailering his boat which weighs 17,500 on the trailer the EGT's will get to 1,500 Degrees on a long hill. Is there anyway to lower the Temps without moving the plate(less Power)??
wannadiesel Sep 20, 2004 05:19 PM
More boost. You should get a TurboMaster or at least a boost elbow and get the boost cranked up to 30 - 35 psi. Should cool things down a lot.
BigBlue Sep 20, 2004 10:19 PM
An exhaust will help some to.
Mcmopar Sep 21, 2004 08:11 AM
Sorry, not enough info was given by me, the truck has a 4" turbo back and a turbo master with 38 psi on the boost gauge under load.
Eskimo Sep 21, 2004 08:15 AM
Get a Scotty II :D
Mcmopar Sep 21, 2004 08:57 AM
So you think the Scotty II is going to lower temps much more than the AFE???
Rattletrap1 Sep 21, 2004 09:35 AM
Can always ease back on the go pedal. Might be able to play with timing.
That's one huge boat to be trailerable...
Mcmopar Sep 21, 2004 09:44 AM
When towing, it keeps you on your toes. Pulling back on the pedal will help cool things off, but I would like to be able to avoid that. This truck is a HOSS, she doesn't slow down no matter how big of a hill-70MPH!!!
infidel Sep 21, 2004 11:21 AM
Definitely. I've installed several AFE's for folks who have complained it did nothing for their egts. Not one complaint with the Scotty, most report a 150° decrease in egts under load. The Scotty sucks cool outside air while the AFE sucks hot underhood. Big difference.
Mcmopar Sep 21, 2004 11:24 AM
Do you have to drill the cowl hole or not?
infidel Sep 21, 2004 12:11 PM
To reap the full advantages you should drill the hole
justinp20012500 Sep 21, 2004 09:35 PM
Ok guys no one has said it... Get twins!!! HX40/35 with a HT3B. Long periods of time (more then 1 min) at 1500 degrees will cause huge problems. I would go with the afe, more filter surface. I would aslo bump the timing to around 15.5 degrees.
If you are only hitting 1500 with a load that big I think the truck is doing very well!!!
Mcmopar Sep 22, 2004 08:41 AM
Twins or just a bigger single?
BigBlue Sep 22, 2004 09:11 AM
I'd just do a bigger single. Either a hybrid 35/40 or a PDR HX40. One of your egt problems is your pushing your turbo to hard. The hx35 is only good up to ~35 psi. After that, it goes way off it's efficiency map.
Mcmopar Sep 22, 2004 09:49 AM
What's the price diff in the hydrid and the HX-40? Best place to buy from you guys that have??
