Location of aftermarket FP guage.
Old Jul 19, 2005 | 03:35 PM
SilverRam01's Avatar
Question Location of aftermarket FP guage.
Hello Board;
My FP guage kit is on the UPS truck, should have it in a day or two. I'm wondering where most of you are installing your gauge at within the cab ? The guage I ordered is a mech. without the isolator. I plan on later adding the triple pillar with Boost / Pyro/ Trans temp at a later date.
So far It's looking like I'll probably mount it just above the floor, at the base of the dash.....this seems a little low / out of sight, but will probably be the most "mount" friendly.
Any suggestions as to potential gauge locations would be appreciated.
Old Jul 20, 2005 | 02:46 AM
2500CTD's Avatar
I have a BD X-monitor and a diprcol FP gauge installed with Geno's Garage cubby hole thingy just right of the radio. I'm running an isolator, and tied into the dash lighting by splicing into the cupholder light.
Old Jul 20, 2005 | 06:51 AM
CTD NUT's Avatar
I would suggest ordering the triple pillar now and installing the FP gauge.....it will save you from going through the hassle of remounting and replumbing your gauge at a later date......the pillar is relatively inexpensive when compared to some of the gauges and you have already stated that you want it, regardless.
Old Jul 20, 2005 | 07:56 AM
lsgibb's Avatar
I have mine mounted in Geno's donut mount under the dash in front of the transfer case shifter.
It works well and I do have a clear view of it when driving I just have to look down. The F/P gauge is not one you stare at all the time like the pyro and boost so it works well under the dash. I went with the Westach electronic gauge much easier install then mechanical and I don't have fuel in the cab.
Old Jul 20, 2005 | 10:52 AM
Thanks for the ideas.......I really didnt plan on putting the FP on the pillar, after Pyro, Boost, and trans temp,.....the pillar will be full. I'm leaning towards in front of the T-case shifter.
Thanks!
Old Jul 20, 2005 | 11:44 AM
Olratlr's Avatar
FP Gauge
I mounted mine just right of the Radio in the little spare change cubby hole.
Old Jul 20, 2005 | 12:46 PM
blackdiesel's Avatar
Registered
olratlr and who ever else that has mounted the fp guage in the cubby hole would yall mind to post a pic of that please? im thinking about that or under the dash by the transfer case shifter. thanks a lot
Old Jul 20, 2005 | 01:36 PM
CTD NUT's Avatar
Thanks!
Another mount you could consider is the single gauge steering column mount from gauge works (Autometer).
Old Jul 20, 2005 | 01:53 PM
lsgibb's Avatar
Re: FP Gauge
I would have mounted mine in that location as well if it wasn't for my heated seat switches occupying that spot already.
Old Jul 20, 2005 | 02:03 PM
BDR2500's Avatar
I have mine mounted on the steering column, great spot for it.
Old Jul 20, 2005 | 06:16 PM
Clunk's Avatar
My cheapo is wire tied to my trailer brake controller...gotta pic in my photo gallery, although I like the top of the dash 3 guage pod.
Old Jul 21, 2005 | 08:43 PM
2500CTD's Avatar
I dont have a pic of my gauge. Sorry. If I see one I will link to it. The previous owner, put a cell phone/cb clip right next to it. I hang my phone there now, and quickly realized that it blockes the FP gauge. Only a concern now, since my LP is going and I keep a closer eye on my FP
NavyChief
32
Mar 15, 2007 06:42 PM
2-Stroke
Nov 21, 2006 06:19 PM
59FORD
Apr 7, 2006 12:28 AM
soundfetish
Feb 26, 2003 03:35 PM
